Finished the foam mount blocks for the fixed pitot static lines. I used a single ply laminate to hold the tubes into the slots cut in the foam blocks for the tubes.
I also pulled the CCA Cover and cockpit airbox from the molds and trimmed them on my bandsaw, finished with a sanding block. They both came out nice.
Seat Pan Area Pitot Staic Line Attachment
Pitot Static Line Attachment Near Pitot Static Tube Mount
