Bill's Glasair Odyssey
Date:  12-30-2008
Brief Description:  Gear Door #1 Fabrication
Removed the LH gear door blank and core from the lower wing skin. The core must be thinned out to meet the final thickness of the completed door. I cut some strips of MDF to the desired core thickness. I taped these strips to the door and sanded the core down to the guides. I then layed out the bevel lines.
I bonded the RH core and skin for the RH door same as the LH covered in a previous entry.
Foam Core with Sanding Guides Sticks  In Place
After Sanding Core to Thickness
Laying Out Bevel Lines
