I layed up a second NACA scoop, cabin airbox, and wing attach angle cover. I did not take any pictures today. Look back a couple of sessions (12/20/08) and the scene is the same. I also stopped by work to do the rough trim on the gear door number #1. I also cut a couple of pieces of aluminum to use to form up on the bottom of the wing for the next step of building the gear doors.
Checked the fit of the new gear trunion nutplate retainer that I started a couple of days ago. It fit fine so I coutersunk the rivet holes in preparation for riveting the nutplates. I drilled out the rivets on the old gear door hinges and removed the hinges. I will probably end up cutting new ones when I fit the new doors.
