I pulled the pieces that I layup last session off of the molds. The released easily with the PVA. After pulling them I rough trimmed the parts using my bandsaw and sanded the edges with a permagrit sanding board. I also pulled the three ply laminate off of the piece of glass that it was layed up on. I traced the existing gear door #1s onto the laminate to prep for cutting them out.
I ended the session by prepping the wing attach cover, NACA scoop, and airbox molds to make a second part (need two of each, L and R)
L to R Wing Attach Cover, NACA Scoop, Cabin Airbox
Landing Gear Circuit Board Cover
3 Ply Laminate Wing Gear Door #1 (two) Outlined On It
