Bill's Glasair Odyssey
Glasair 1 RG
Main Gear Actuator Recess RH
Put down the two ply laminate in the RH side recess. Peel plyed and vacuum bagged. Hopefully this will make for a nice clean patch/repair.
Recess Vacuum Bagged, resin starting to soak into the bleeder
Eagle II Home
Glasair 1 RG Home
869
Ailerons and Flaps
71
134
Controls - Hardware
Finishing
Jig Fabrication
Kit Pick Up
Layups - Misc
Metal Fab-Alum
Metal Fab-Sheet Met
Metal Fab-Steel
Molds
Rudder Pedals
Shop Prep
420
