Brief Description: Main Gear Acuator Recess - RH Wing
One of the previous builders had made a recess for the RH actuator. Unfortunately it was a little undersized. I spent some time figuring out how much it needed to be expanded. I cut out the existing laminates and started sanding the foam bevels. After I was happy with the shape I Q-celled the exposed foam and sanded the perimeter as well as tapering the old laminates so the patch will blend well.
Tape outlines the new cut. Section removed on the left
After sanding the perimeter and q-celling the foam
