Yesterday's work came out pretty good so I decided to continue with the peel ply on the LH skin. This session is a repeat of yesterday's entry. This time it went a little quicker. I used a 150 gram batch of resin with some left over. I have a total of twenty hours adding the wing walk reinforcement! Will I ever finish?
Update: The laminate came out good and the edges are really smooth with the existing skin. Unfortunatey the are two small bubbles that snuck in after I left the hanger (lower right corner and along the bottom edge of the foam). Otherwise great!
