Re-made LH landing gear hydraulic tubing from the landing gear bay to the rear spar elbows. Fabricated the RH hydraulic tubes from the RH rear spar elbows to the hydraulic manifold. Drilled the two mounting holes for the manifold. The blue tape in picture two are pieces of poster board taped to the rear spar in the position of the flap reinforcement wedges that will be added during the flap construction. The tubing has to dip down in these areas to clear the flap pushrods.
Landing gear bay tubing bottom tube is for brakes.
