Brief Description: Pitot Static Tubing, Brake system tubing
I have decided to run hard tubing from the LH seat pan bay out to the LH wing opening where the Pitot static tube will be (I have a combined unit). I drilled holes for the two .25 dia alum tubing in each of the wing ribs between the bays. I also spent some time figuring out how to route my hard brake lines. Spent a lot of time cleaning the shop, which I don't count as building time.
LH brake line, Pitot Static in background
RH brake line in seat pan area
RH brake line looking through wing seat pan opening
