Bill's Glasair Odyssey
Glasair 1 RG
S/B 161
Primed Inside Landing Gear oleo strut - bottom onl
Sprayed primer on the areas of the oleo tube per the S/B 161. I used PPG NC271 epoxy primer that I had left over from previous painting projects. Time includes set up, mixing and clean up.
Eagle II Home
Glasair 1 RG Home
869
Ailerons and Flaps
71
134
Controls - Hardware
Finishing
Jig Fabrication
Kit Pick Up
Layups - Misc
Metal Fab-Alum
Metal Fab-Sheet Met
Metal Fab-Steel
Molds
Rudder Pedals
Shop Prep
420
