I bead blasted the side brace brackets and powder coated these parts and yesterdays parts. All white, I used powder from Harbor Freight which I had never tried. Worked good, same result as Eastwood powder. I then reassembled all the back plates and the the third door actuator arm. I spent a lot of time working on the side brace actuator arm. I drilled out the rivets and then tried to push out the rivets in the press. I did not have a punch handy so I used a drill bit. Bad plan, broke two bits off during this exercise. I took me a long time to rectify this mistake. I ended up having to remake the aluminum spacer, match drilled and re-riveted. This took a long time... Anyway all done, finally,
