Bill's Glasair Odyssey
Glasair 1 RG
Tank Venting, Filler Cap Flange Fitting
Located and drilled the LH top skin for the welded -6 bulkhead elbows that I will be using for main tank vents. I also filed and sanded the gas cap sleeve flush with the LH top wing skin.
Eagle II Home
Glasair 1 RG Home
869
Ailerons and Flaps
71
134
Controls - Hardware
Finishing
Jig Fabrication
Kit Pick Up
Layups - Misc
Metal Fab-Alum
Metal Fab-Sheet Met
Metal Fab-Steel
Molds
Rudder Pedals
Shop Prep
420
