Brief Description: Pitot Mount - Inspection Cover Nutplates
Pulled the streamlined tubing out of the wing from the opening I cast in cabosil last night. It came out good. Marked the inspection covers for the mounting screw holes (5 each to accept 4-40 100 deg countersunk screws). I then match drilled the flanges in the wing openings. Click bond 4-40 floating nutplates were installed in the holes.
