Brief Description: Painted Aileron Pushrod Tubes - Prepped Alum Parts
My aileron pushrod tubes are to long to fit in my oven for powder coating. I was forced to use a rattle can. The tubes were sanded with 400 grit paper cleaned with MEK and then shot with primer and then a coat for gloss white Rustoleum. The aileron bellcrank halves, bellcrank mounting angles, AP servo mounting bracket were sanded, cleaned, and acid dipped in preparation for anodizing.
