Brief Description: Repaired Old Flap Ratchet Plate Mounting
My wing originally had the manual flap handle attached to the A Rib. The previous builder had removed the hardware and filled the holes with micro or cabosil. I prep sanded these areas on the A rib and put a one ply sealing laminate over the filled areas.
