I decided that I did not like one of the LH (more complicated) bellcranks came out. One of the bends was a little to sharp. I had to bend two of the bends on the vise and not so good. I layed out a third blank, trimmed it with the foot shear, and sanded it to shape on the disc sander and drum sanders. I drilled the RH bellcranks halves to the center bearing and drilled the pushrod bearing holes. I then disassembled them and deburred.
