Brief Description: Flap Torque Rods, Control Sticks
Cut two new flap torque rods (for electric flaps) and match drilled them to the control arms. The control arms were already drilled to fit the old torque rods (manual flaps), thus the need to match drill. I cut the tubing on a roll in band saw and sanded them square and to final dimensions on a disk sander. I also cut two new control sticks out of heavier wall thickness tubing. These fit the control yokes much better that the one that the previous builder had fabricated. These were also match drilled. I used the mill for all the match drilling. I worked great but took a lot of time.
