Bill's Glasair Odyssey
Date:  10-28-2007
Number of Hours:  6.50
Brief Description:  Cleaned Wing, Removed Aileron Bellcranks, TD tiedo
Started looking at the status of the wing contruction. This part of the build is about twenty years old. First step is cleaning out all the wing bays. I used water and a scrub brush for this. After scrubbing away I used my wet and dry vacuum to suck up the water and dirt. Photo 1 shows one of the cleaner bays before I started. My kit began life as a tail dragger. I noticed that the wing had two sets of tiedown plates installed. The original TD config plates were not well done. There was also a mystery hole on the other side of the rib with a threaded insert wit ha star shaped base. The inboard RG plates look nice and will be retained. Photo 2 shows the two old inserts after I cut out and pried them loose. Picture three shows the area afte a little work wit the dremel. I now have to go back in and hand sand in preparation for the repair. I also removed the aileron bellcrank angles that can be seen in photo 2. They turned out to be well made so I will strip the rattle can primer off of these and have them anodized. I am doing the same with the actual aileron bellcranks. The right hand side will be retained and the left will be remade with a provision for an autopilot servo attach point.
Typical Bay Before Cleaning
Two Plates Removed From Wing Skin
About 15 Minutes Later
