Bill's Glasair Odyssey
Date:  9-20-2007
Number of Hours:  1.50
Brief Description:  LG Circuit Card Cover Mold
Finally got back to finishing the mold for this piece. I did more sanding, priming, filling, etc. I put a final coat of white paint on the mold tonight. Now it just needs waxed and PVA sprayed before use. Going to the Red Bull air races in San Diego in the morning, then off to the UK for work. It will be a week or so before I get back on this project!
At lunch today I drilled the first hole in the elevator joiner (aluminum channel) that the elevator halves will bolt to. The hole I drilled today was for the control arm/counterweight. The second hole will be drilled after fitting the assembly to the fuselage.
