Still working the mold! Cut a base plate for the form. Screwed the two together with drywall screws. Started working on the junction between the base and the form using Bondo.
Still more sanding, sealing and painting to go.
I also cut a piece of MDF and some clamp blocks for use a welding fixture for the elevator control arm/counterbalance
