Brief Description: Finished flap actuator control arms, cut rudder an
Finished trimming the flap actuator control arms. Used the mill, files, sanders etc. I found some more P4 hinge stock so I cut the remaining two flap hinges (12") and the two rudder hinges (8"). I cut these on the bandsaw and then finish with the disc sander and final finish with files.
On a non-related task I reconfigured the landing gear hydraulic pump per the instructions. The reconfiguration involves separating the motor from the pump head and rotating the motor so that the wire leads exit 180 degrees from the manual pressure relief petcock. This involves removing two nuts to disconnect the motor from the pump. There is an o-ring between the two. On mine the o-ring had taken a set in a bad way. The pump is over twenty years old and has never been used so I suppose this makes sense. Anyway, I replaced the o-ring, it is an MS29513-132 size.
