Brief Description: Made gear door #3 hinges, drilled nose gear hinge,
Used the drill fixture described in the last entry to drill the nose gear door hinge. After that I modified the fixture to hold the wider flange P6 style piano hinge (milled the step wider by .25 inches).
Fabricated the two gear door #3 piano hinges out of P6 hinge stock. Drilled per instructions using the modified fixture on the mill at work.
Fabricated the six engine mount washers out of .125 thick 2024-T3 aluminum sheet. I used a combination of the mill, the roll in band saw and sanding discs to shape these parts. The washers will be further trimmed to fit the backside of the firewall in between the composit engine mount gussets.
