Cut our two wear blocks for the #3 gear doors. These pads will rivet to the gear doors and provide a wear surface for the end of the gear door spring.
These are cut out from 1/8" nylon sheet. These were drilled on the mill as a stacked pair to make them identical. I then trimmed the blocks pads to rough size on the bandsaw and finished them off with the mill, again as a stacked pair. The radii were sanded in with a 12" sanding disk
Finished Nylon Blocks, Dye Chem evident on right block
