Brief Description: Shaping Rudder Actuatorm, Bondiwing attach Bushin
Final shaped the radii on the rudder attach fitting using a hand file and sanding block.
Installed the wing attach fitting bushings on all four attach angles. I installed these using a Loctite product to take up any excess assembly clearance. Two of the angles I could drop the bushings into with maybe .005 clearance. The other two angles were a light press fit. The Loctite will ensure that there is no slop between the bushings and the angle plates.
