Brief Description: Pitch Trim Clamp, Tack Weld Jig
Made a quick jig to hold the pitch trim clamp parts aligned during the tack welding. This jig holds the two bolt sleeves against the main tube at the proper height. After welding the weldment will be cut in two halves (horizontally in the photo) and the spring cartridge tab will be added to one half.
