Bill's Glasair Odyssey
Glasair 1 RG
Nose Gear Strut Z-Channel
Drilled and shaped Z-Channel for nose gear spring mount using the mill. Continued sanding in radii on the other shaped angle pieces using a 1 inch belt sander.
Finished Bracket
Eagle II Home
Glasair 1 RG Home
869
Ailerons and Flaps
71
134
Controls - Hardware
Finishing
Jig Fabrication
Kit Pick Up
Layups - Misc
Metal Fab-Alum
Metal Fab-Sheet Met
Metal Fab-Steel
Molds
Rudder Pedals
Shop Prep
420
