Bill's Glasair Odyssey
Date:  1-4-2007
Manual Reference:  A10, C2, D8
Brief Description:  Wing attach, rudder bellcrank mount, elev trim pus
Drilled/milled forward wing attach fittings. Drilled aft wing attach fittings. Drilled rudder bellcrank mounts. Fabricated elevator trim pushrod (minus final riveting). All work performed at work using a mill and lathe
