Cut alum angle to length for the following parts: Seat belt brackets, Rudder spring brackets, Gear Door #3 spring mounts, Nose gear tunnel hydralic union bracket, Elevator trim lever base, Gear Door #3 actuating arm stops, Gear Door #1 strut bracket, Gear Door #3 cable attach fittings.
