Brief Description: Flap Actuator Fitting and nutplates
I had to add one more ply to the four ply filler laminates put on yesterday. I used a heat lamp to accelerate the cure. A then sanded the filler laminates flush with the piano hinge. I then located the actuator fitting and clamped it in place. I then drilled the four mounting holes using a brad point drill bit to match drill the flap to the actuator fitting. I then installed the two inner surface rib nutplates with a mill fiber mixture per the instructions. May get to close the flap this weekend
