Brief Description: Counterweight arm mounting holes drilled
After the three ply layups had cured I put the ailerons back on. I fixtured them in the neutral position. I used a string to determine the neutral position per the Super GII instructions. I then put the counterweights back in and used the arms to pilot the drill to drill the 20 lb foam ribs.
