Brief Description: Flap Hinges - LH flap to wing attachment
I drilled and cleco'd all the flap sided hinges using a spacer underneth them that was the same thickness ass the trailing edge. I then fit the LH flap to the wing and located clamped and drilled the wing side hinges. On the inboard side a pair of small vise grip clamps can be used to hold the hinge in place. The outboard side does not lend itself to traditional clamps. I used hot melt glue to hold it in position which worked pretty good.
