I drilled and clecoed the aileron hinge halves to the aileron shear webs. I located the hinge position with a strip of wood that I ripped on the table saw. The strip was the exact thickness of the trailing edge skins at the hinge locations. This should result in the ailerons being flush with the bottom of the wing skin. I held the hinges in place with jorgenson clamps while drilling. Worked good. I also grabed one of the flap panels and started laying out the hinges for it.
Backside or shearweb - note the aluminum reinforcement
