Completed the two ply layups on both of the lower aileron skins. I did the layups one at a time and let them tack up before adding the second layup. I used 100 gram batches of resin for each ply. They came out nice I am optimistic!
I also added three plys of 2 inch wide tape over yesterdays cabosil fillets that I bonded the wing tips together with. Now they should be pretty solid. I put them back on the wing to cure as I still need to force them on. My plan is to heat them up to reform them a bit for better fit. We shall see.
