Bill's Glasair Odyssey
Date:  11-29-2010
Number of Hours:  4.00
Brief Description:  Ailerons Foam Core and Wingtip Joining
Worked on taking a little twist out of the table. I then added double sided tape to the surface of the table. The plan is to stick the lower aileron panels to the taped flat table. Then I will add the 1/4 inch foam core, shape and cover with two plys of bid. Once cured I will remove the panels from the table and presto, flat bottoms. At least that is the plan. I stuck down the aileron skins to the taped surface which looks like it will work great. I then bonded the cores down using a thick q-cell mix. I weight the core down with bricks. After they cured I beveled the foam core with sandpaper and then sealed them with a runny q-cell. I then prepared some square block to butt the shear webs against to ensure that the shear webs are at a 90 degree angle to the aileron bottoms. On one side the web was under 90 degrees and I could just anchor the block against the shear web and it was self jigging. On the other side the web was over 90 and I had to anchor the square block and then clamp the shear web to the block. I then added a fillet of bondo between the block and the outside surface of the shear web to hold it in position during laminating
Foam cores weighted in place
Foam core before beveling
After beveling the core
