Today I positioned and drilled the mounting holes for the pitch trim lever. The angle mount through the top wing skin a little left of the wing center line. The holes are drilled just behind the spar cap but forward of the foam core taper in the wing skin. I then cut an access hole in the LH seat pan so that I can adjust the trim system friction without removing the seat pan.
