Brief Description: Re-Cut and taper Wing Spar Caps
Had to go back and re-taper the spar caps. The manual states to leave 7" on the vertical sides untapered. So I let 7" on the top and bottom sides. Not good. A good taper is needed the entire length sincal all vertical pieces are 4 7/16" long and to clamp everything requires a straight taper the entire length of the spar cap. Also started cutting the 1/2" vertical pieces for the outer wing spars.
