Brief Description: Prep Work for Plywood on Fuselage Sides
Prepared plywood for epoxing to fuselage sides. Sanded outside areas of ladder to ensure plywood would lie flat against the vertical, longitudinal and gusset areas. Set up Shop Smith to scarf plywood pieces that would be epoxied to the fuselage sides. Bought a digital level to set table at 10 degrees. Used a drum sander in the drill bit holder. Worked very well to scraft the plywood.
