Brief Description: Cutting fuselage bottom gussets and fabricating cl
Cut and fit small wooden gussets for each of the cross members. No two are alike due to the many compound angles. Plans require 90% surface contact. Cut clamps from a 4" PVC pipe to hold the gussets in place once T-88 applied.
