Brief Description: Epoxy Plywood to Fuselage Ladder Sides
Epoxied plywood to the fuselage ladder. Plywood nailed to table. Used additional nails to keep ladder from sliding around on the plywood after T-88 applied to both the plywood and the ladder. Then a rough cut piece of plywood in the shape of the fuselage side was laid on top of ladder and blue foam strips laid on it upon which cinder blocks were laid to apply a "clamping" pressure to the whole side. The manual called for stapling the plywood to the ladder, but another builder had used this method and it did not require removing a lot of staples.
