Drilled Holes in brake flange on right-hand landing gear and installed the brake mounting/torque plate. Filed one side of washers on a bevel and with a slight flat edge to fit the tight areas between the bolts and the welds of the flange on the axle tube. The close fit stop nuts worked very well.
