Brad Wilkinson, Bearhawk #1062
Date:  3-15-2008
Number of Hours:  2.50
Brief Description:  Mounted Brakes on RH gear
Drilled Holes in brake flange on right-hand landing gear and installed the brake mounting/torque plate. Filed one side of washers on a bevel and with a slight flat edge to fit the tight areas between the bolts and the welds of the flange on the axle tube. The close fit stop nuts worked very well.
Test-fit the caliper and wheel - looks great!
Three 5/16
Three 5/16" holes - critical fit!
Brake mounting plate bolted.
Great fit.
Great fit.
