Jay and Bryce used a "manometer" to fill the right wing tank with 1 psi to test for leaks. The fuel cap is vented, and has a gasket that is not completely airtight so we had to use our hands to seal the fuel cap. The tank performed well with no apparent leaks. The next step will be to fill the tank with fuel to ensure no leaks.
fuel sealant/lubricant for tank fittings
brass fittings inserted into fuel tank
Jay sealing the fuel cap entrance to check the tank for leaks.
