Brief Description: covering work, fuel tank preparation
Terry, Jay, Bryce, Michael, and Art all worked a little over 2 hours on multiple porjects including: 1) started the "bias tapes" section on the horizontal stabilizer 2) Fittings test fit into the right fuel tank in preperation for pressure testing of the fuel tank to be completed next week 3) Working to craft "saddles" that will hold the rudder cables on the pulleys if there is slack in the line. 4) sanding the sides of the wing lockers to fit 5) sawing off the attahment points for the wextra wing bays on the wingtips.
bias tapes being applied to horizontal stabilizer
terry making templates for "saddles" that will go under the rudder cable pulleys
Michael uses a dremel to shape the plexiglas sides of the wing lockers to fit.
