EAA Chapter 24 Kitfox
Date:  1-9-2019
Number of Hours:  17.00
Brief Description:  Left Wingtip attachment work
Eric Muehlberg, Jay Burgess, Hannah Brown, Jordan Newton, Brian Rohr, Derek Orr, Pete Taylor, Nicholas Rutledge, and Ferenc Deak were each present for around 2 hours.
Work was primarily centered on attaching the left wingtip. We used a centerfinder to locate where to drill the holes (1/8" bit) for the screws that will hold the wingtip in place. All the holes got drilled, and clecos are in place awaiting the screws.
Pete, Bryan, Jay, and Derek discussed insturment layout. We discussed leaving an area for a transponsder and a radio, as well as researching size and types of switches and circuit breakers that we intend to install on the right side of the instrument panel under a set of 5 engine instrument gauges.
Eric shows Hannah how to align the trailing edge of the wingtip
Jordan used a straighedge to align the wingtip while Ferenc holds it in position and Eric drills
Pete and Bryan discuss instrument layout
