EAA Chapter 24 Kitfox
Date:  8-30-2017
Number of Hours:  11.00
Brief Description:  Wing lockers, leading edges, control system.
Terry, Bruce, Bryce, Jay and Greg were present.
Eric ordered and delivered some supplies from Aircraft Spruce. Most of the supplies were chemicals. Because Greg has extensive experience in adhesives and chemicals, he volunteered to inventory the chemicals and make sure that we have the proper safety and handling gear on hand when we start using them.
Bruce continued to work on the wing lockers. He measured and drew up the dimensions for the strips that we will need for the wing locker doors once the airplane is covered. Bryce volunteered to cut the strips with his CNC machine and he took some scrap plywood with him for material.
Jay and Bryce used the leading edge template to test fit the leading edge. Next week we will need denatured alcohol for cleaning, a saw for trimiming the ends, and adhesives for attachment.
Bruce's drawings for wing locker door catch dimensions.
Bryce and Jay test fitting leading edges
Leading edges test fit.
Copyright © 2001-2018 Matronics. All Rights Reserved.
