EAA Chapter 24 Kitfox
Date:  7-12-2017
Number of Hours:  15.00
Manual Reference:  W-B Wing Alignment
Brief Description:  Working on Wing Alignment
Eric, Jay, John Marr, James, and Terry were in attendance. We spent several hours adjusting the lift struts to see if we can get the wings aligned. They were dead square to the fuselage and within a degree or so in washout to one another. They swing back smoothly, but are out of alignment when folded back. We believe that they are close enough that with some further adjustments to the lift struts we can get them perfectly aligned. We noted that we are using a digital level, and if we are just looking at the bubble on the level, we would be very happy with the present condition. It is possible that we are well within an acceptable tolerance, but the accuracy of the digital level is causing us to notice minor alignment errors that we wouldn't otherwise notice.
Landing Gear off and Wings attached
Wings aren't lining up when folded back
Copyright © 2001-2018 Matronics. All Rights Reserved.
