BUENO'S WEB SITE
Date:  3-12-2006
Number of Hours:  5.00
Manual Reference:  rib placement/skin
Brief Description:  leading edge skin guide fwd rib location
Prior to rib placement do not use bolts in structure. the drag braces and compression tubes will have to be moved to allow ribs to be inserted. Permanently mount tank and all forward bolts in spar fittings. Rivet the #13 ribs to spar. Put tip skin on with rivets in text, leaving the 5 fwd rivets out on inboard #13 rib. Slip leading edge skin under tip skin and clico. Between the skins and spar fittings you will use 100 1/8 and 25 3/16 clicos or junk bolts.
loose rib location
loose rib location
checking tank/rib clearance
it fits
it fits
