Brief Description: sit up Elevator trim servo. linage and horn
Aligned and drilled holes for elevator trim horn. Located and drilled holes for elevator trim servo cut hole for trim linkage cut linkage rod to length and assembled rod ends with horn & servo motor celled in place and horn attached ran the servo through full travel with a battery checking linkage clearance, and elevator trim tab travel
