Brief Description: Worked on Skin and more of the frame
Lined up and pre drilled skin. Aligned/Drilled/Clecod end ribs with outside hinges Cut brackets aligend drilled and cleco to center bracket Aligned, drilled Cleco Center bracket to Center ribs and skin Aligned and teped in place Nose skin
