Mike and Elisabeth CH750 build
Date:  7-2-2010
Number of Hours:  1.50
Manual Reference:  75-TA-1 pg3
Brief Description:  Front Spar and Doublers
After drilling, clecoing the doublers to rear spar I drilled and clecoed the doublers to the front spar. Then cut the 2 angle pices, and aligned, drilled, then clecoed to the front spar. Placed both spars on bench together in preperation for next step installing the ribs between them.
Front and rear spars
